Oil?
Old Apr 14, 2004 | 06:26 AM
fastrnuGSR's Avatar
fastrnuGSR
Default Oil?
i am getting ready to change my oil in my 95 GSR. it has 82000 mi on it, should i be using any special type of oil or anything?
Old Apr 14, 2004 | 06:47 AM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
The black stuff ?
5w -30 is what most people recomend, I like using hte valvoline high mileage on my car becuase of the extra additives.
Old Apr 14, 2004 | 07:01 AM
LT's Avatar
LT
The deer had to die!
its getting warm out, use 10W-30 - more protection and thicker than 5W-30 (good in winter).
Its up to you...do you want to switch to synthetic or what?
Old Apr 14, 2004 | 07:13 AM
Maxx44's Avatar
Maxx44
Former Vendor
use synthetic......Amsoil
Old Apr 14, 2004 | 07:18 AM
98teggs's Avatar
98teggs
if you switch to syn. dont go back only use syn from then on
Old Apr 14, 2004 | 08:48 AM
shivers's Avatar
shivers
Moderator Alumni
That is a myth.
2005 s2000
Old Apr 14, 2004 | 11:29 AM
LT's Avatar
LT
Originally Posted by shivers
That is a myth.
very true. if you're burning synthetic oil (because it's thinner and lighter) then you can switch back to dino (conventional) oil.
Old Apr 14, 2004 | 12:27 PM
pirate252's Avatar
pirate252
I wouldnt recomend this, i used to think this way, but the only difference between 5w-30 and 10w-30 is the startup thinkness until the oil gets warm, these bothw ill preform the same at operating temp, and if you change to 10w it makes cold starts harder on your engine (even if its warm outside) If you are somwhere when its hot ouside use a higher last number to make it preform better under higher temps...
Synthetic makes older engines leak becasue all the molecules are the same size, and it has cleaners in it that will eat all the gunk that are now holding the leaks that dino oils will keep in tact...so running synthetic oils will somtimes clean the eninge out and create more leaks...And you shouldnt have a problem burning it, its actually more resistant to burning at high engine temps...
And yes this is a myth
Matt
Nightshade
Nov 21, 2003 10:51 AM
Fujiwara Takumi
Accord
4
Sep 25, 2003 11:25 AM
coco8724
Engine Swaps, Tech & Tuning
5
May 5, 2003 06:59 AM
Fast_Draw
Accord
4
Mar 19, 2003 09:09 AM
AwwsChwA
3
Sep 18, 2002 05:03 PM
