building a ls/vtec?
Old Apr 11, 2004 | 05:15 PM
customX4306's Avatar
customX4306
Default building a ls/vtec?
i just recently sold my 97 civic ex and i plan on buying a 95 teg ls and i plan on doing a ls/vtec conversion, i was wondering what exactly i would need in oreder to do this conversion??
Old Apr 11, 2004 | 05:19 PM
AP2's Avatar
AP2
Moderator Alumni
You'll find alot of info if you would do a search on this subject.
Old Apr 11, 2004 | 05:34 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
:yes::a:
Old Apr 11, 2004 | 08:26 PM
acuragal03's Avatar
acuragal03
well, people on here on other sites you tell you that you need things that you dont really need. so...its really very simple. i asked a honda mechanic who will be doing my ls/vtec. he has done over a hundred ls/vtec setups and is very well known in virginia. anyway...you will need a vtec head, whether it be b16a2 b18c1 or b18c5(make sure it comes with all the internals like cams cam gears sensors etc), you need to get your oil lines drilled and run, a matching intake manifold, throttle body, fuel rail, injectors, all necessary gaskets, ecu, hondata or vtec controller. it is recommened to replace the piston rings, water pump and timing belt, and oil pump, even though the b18b parts will still work. also, you will probably want headers, intake and exhaust, so you might as well replace these with gsr applications. however, this guy told me that my ls exhaust manifold will bolt right up to any b series head. a good deal on a head would be anywhere from 300-500. getting the oil lines run and everything put together will cost around 600-700. it is expensive and pretty unstable. but the outcome can be around 140lbs of torqueat the higher rpms and depending on if the head is built or not, you can get anywhere from around 175-200hp. good luck
Caster Troy SI
Engine Swaps, Tech & Tuning
5
Dec 10, 2003 02:23 PM
Caster Troy SI
2
Dec 9, 2003 05:20 PM
Caster Troy SI
Dec 9, 2003 01:01 PM
LSVTECKING
Oct 9, 2003 10:45 AM
HeavyCivic
92+ Civic/EL & Del Sol
13
Oct 1, 2002 02:37 AM
