plz help my radio works but there's no display
Old Apr 6, 2004 | 06:39 AM
smokedaddy's Avatar
smokedaddy
Banned
Default plz help my radio works but there's no display
i know my radio is good as new but when i decided to hook it up myself everything went wrong. Now i have no display and my radio and amp always stay on even when i pull my key out. I've got power connected to the yellow and red and the constant on the white and blue and i have a red and black wire thats not connected to anything at all can some one help me with these confusing color codes?
Old Apr 6, 2004 | 09:21 AM
SuperMario98Ex's Avatar
SuperMario98Ex
All I can tell you is to get a multi-meter check the wires for Ohm's but it sounds like you migth have a short some where were your power just keeps on flowing.
You might want to check it with voltage although the car is off there should be power coming from one of them wires.
Old Apr 6, 2004 | 10:53 AM
strychnine's Avatar
strychnine
i am legend
nevermind
Old Apr 6, 2004 | 10:57 AM
strychnine's Avatar
strychnine
i am legend
Illumination=Red/Black
does your hu have an illumination wire?
Old Apr 6, 2004 | 11:01 AM
strychnine's Avatar
strychnine
i am legend
also maybe try switching the two wires around. your constant is yellow and switched is red, correct?
Old Apr 6, 2004 | 11:02 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
Ok, to start with constant power should not be connected to the blue and white wire... that is a remote turn on wire that sends a signal to an amp or power antenna to turn on. Red is the accessory wire, which is triggered when the key is turned on. The yellow wire is the constant power wire, which gets power all the time.
Get a wirring diagram for your deck... make sure everything is right... it definatly sounds like you have it wrong.
Old Apr 6, 2004 | 11:03 AM
SumAccordGuy94
Older Honda Fanatic
illumination is an orange wire if the deck has the need for one.
Old Apr 9, 2004 | 09:02 AM
smokedaddy's Avatar
smokedaddy
Banned
thanks for all your help everything is good now but i think i might have shorted out my display,I can still use the cd player but no display. This is a very aftermarket radio with no name but it does have like two glass fuses and every once in a while the display will cut back on.will replacing the fuses give me display or could the problem be internal?
Old Apr 9, 2004 | 09:27 AM
SumAccordGuy94
Older Honda Fanatic
it it has a detachable faceplate, remove the face and carefully clean the contacts on the face and the deck with rubbing alcohol on a Q-tip. Other than that, I have no idea.
Dimi
4
Feb 15, 2004 01:46 AM
senseiturtle
Nov 17, 2003 06:52 PM
Daniel
News & Rumors Archives
9
Sep 12, 2003 07:46 AM
noyintegra
Jun 26, 2003 10:45 AM
Tirod
15
Jan 16, 2003 09:17 PM
