my clutch is getting weird
Old Mar 16, 2004 | 11:59 AM
Jason Moon's Avatar
Jason Moon
when i rev around or driving on 5000 rpm, i hear this "clinG clinG" noise from the clutch. it sounds like a bunch of cans tied up behind the car while the cars moving. the clutch itself is stock but was replaced for a new one before i bought the car.
also my friend has a integra but his a/c doesnt blow cold air and its weak. what would you need to switch out inorder to feel the cold air again?
Old Mar 17, 2004 | 03:11 PM
Jason Moon's Avatar
Jason Moon
no one knows? i really do need help..
Old Mar 17, 2004 | 03:16 PM
Bryce's Avatar
Bryce
I wish I could help but I'm a novice. Hopefully one of the whizzes on here will see this thread. Sorry man
Old Mar 18, 2004 | 03:20 PM
Azcheron's Avatar
Azcheron
BUMP! i need to know A/C problem as well with my GSR
Old Mar 18, 2004 | 05:45 PM
PY 01-0972's Avatar
PY 01-0972
the last time I heard that sound in my car the throw out bearing was toasted.
Old Apr 9, 2004 | 04:35 PM
01usjdmr's Avatar
01usjdmr
Sounds like possible throw out bearing. A/c problem could be a fan going bad. I have seen quite a few of those, you really need to diagnose that properly, it could have a leak.
Old Apr 10, 2004 | 09:13 AM
TonyTheFarmer's Avatar
TonyTheFarmer
if you noticed the ac getting worse and worse over time, then its most likly a leak in the ac system. Just pray to the car gods its not a whole in the compressor, because that can cost a ton of cash to fix. This most likely wont be a do it your self job, you will need to have an ac guy run some test on the car. good luck
