Do you guys have *THIS* particular model stateside?
Old Aug 4, 2002 | 01:47 AM
Chasesdragons's Avatar
Chasesdragons
Default Do you guys have *THIS* particular model stateside?
Guys n grls,
I have a Honda Del Sol VXi. Its JDM with a D15B2 engine, Chassis number begins EG1. The date of manufacture in 1992, Osaka (?).
Do you have something similar out there in the states? Was this direct US sales model or imported? What is it called-Si, VTi, S, xxx??! (apart from the obvious due to lack of power!). coupla other Qs if you can answer them:
-What other stateside cars did the engine occur in (helps looking for go-faster bits)
-Anybody bought Kayaba AGX shox for these?
- anybody fitted indiglo dials to these or similar? What model's indiglos did u use?
I really would apreciate you input, as there is a much better knowledgebase on your side than here in the UK.
Udhi
Old Aug 4, 2002 | 06:25 AM
Bl@ck's Avatar
Bl@ck
Sinner
yep.. it's a del sol. they came in s, si, and plain old del sol i think. in japan they're called a CRX. i do know aboutthe indiglo's.. i think 92-95 works on those and they're really easy to install.
Old Aug 4, 2002 | 11:02 AM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Which Sol had the B16A3? Was it called the Del Sol VTEC or the Del Sol Si?
*phew, finally got that off my chest *
Old Aug 4, 2002 | 11:11 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The Del Sol VTEC had the B16, the Si had a D16
Old Aug 4, 2002 | 12:38 PM
Chasesdragons
But did you guys get a DEl Sol with an SOHC 1500cc VTEC, stateside? What was it called? what years did it get sold out there? The JDM designation is "Del Sol VXi"
and, WTH cant I see my pic??! I can see Dom's lady with the immaculate tummy as well as inspyrals manga babe, but not mine!
BTW, /^Blackmagik^\, The 92 indiglos dont fit cos theres a diff in rpm, speedo AND the number of safety light cutouts in the rpm guage. Have a look at the following link, I stuck it up for dealers to check and see if they can get me a set to fit.:
Click Here
Old Aug 4, 2002 | 12:50 PM
Chasesdragons
Doh!!!
I just noticed that the message is in the wrong area! My profuse apologies, I have requested Chris the Webmaster to do whatever he thinks is correct (Del Sol section pls??) . Sorry to take up your bsandwidth.
Regards
Old Aug 4, 2002 | 02:49 PM
s2ksol's Avatar
s2ksol
For a wide variety of helpful information about the US sol then check out www.teamdelsol.com FAQ.
US models: S, Si, and VTEC
93 S 1.5 non-VTEC d15 engine 102HP
Si 1.6 SOHC VTEC d16 engine 125hp
94/95 S 1.5 non-VTEC d15 engine 102hp
VTEC 1.6 DOHC VTEC b16a3 engine 160hp
96/97 S 1.6 non-VTEC d16 engine 106hp
Si 1.6 SOHC VTEC d16 engine 127hp
VTEC 1.6 DOHC VTEC b16a2 engine 160hp
Old Aug 4, 2002 | 07:07 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
the 1500 vtec was never available in a sol in the US... The closest you can get is slapping a d16z6 head on a d15b7... Anyway, intakes, exhaust, cam gears, ignition junk, suspension should all be the same. With indiglos, whoever said the civic ones work has never been in a sol. The ones from an Si will work, but it will be in MPH, not KPH... But any gauges made for any sol will work. It will just show a different redline. Remember what it's supposed to be, and you have no problem.
Old Aug 6, 2002 | 01:35 AM
Chasesdragons
Thanks for the info guys. Rubber-side down and all that..
Old Aug 7, 2002 | 02:06 PM
SoloSol's Avatar
SoloSol
The KYB's Rock!
I have them on my sol and my girlfriends EH2
