Check engine light ? Code 9
Old Jun 17, 2003 | 01:33 PM
Rising Sun 616's Avatar
Rising Sun 616
Can anyome tell me why my car is throwing Code 9 ? Which is the cylinder sensor ? :?
Old Jun 19, 2003 | 01:31 AM
ThisFlyGuy's Avatar
ThisFlyGuy
try unpluggin your battery for a few minutes- plug it back in and see if the light comes back on...
Old Jun 19, 2003 | 06:39 AM
Trey
Guest
Posts: n/a
Code 9 =
CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
Find the sensor in a manual then make sure yours is plugged in and working
Old Jun 19, 2003 | 09:48 AM
TypeR 801's Avatar
TypeR 801
I had that code when I lost my distributor.
I'd take the distributor cap and rotor off and inspect your distributor assembly. In my case, the rotor screw came loose and rattled around for a while I'm sure causing damage to the inside of the distributor. I got the code after the car begin to miss intermittenly. By that point, it was too late, I needed a new distributor.
Originally Posted by Trey
Code 9 =
