At the dyno again, HyTech powered car, plots and modification list inside
I just wanted to head to the dyno and make a few changes to my part throttle maps, vtec MAP activation, and some other minor changes...so while I was there I decided to get a few full throttle runs in...
Thanks to Lawrence at DynoSpot Racing for his time and assistance.
SMOOTHING WAS SET TO 1 just to show you how smooth the plot is. I had to give it to you in MPH because we were having trouble with the RPM signal.
full size edition, cut and paste into your browser window:
http://www.imagestation.com/pi...g.jpg
Here is the RPM plot...as you can see it's hard to read :?
full size, cut and paste into your browser:
So...anyone know what gearing I was running?
Anyone know where VTEC is at?
Both of those questions are trick questions, and if you know them it's because I've told you what they were
Car has 56,000 miles as of the drive home from the drive home from the dyno.
Parts Installed:
Comptech icebox and intake
Mugen headgasket
Hondata intake manifold gasket, street setup
Hondata S200
HyTech header and exhaust, test pipe
toda cam gears +5, +5
Prelude '97+ 290cc/min injectors
Have a good day :beer:
Austin
p.s. almost forgot to post on this site
ops:
Parts Installed:
Mugen headgasket
Hondata S200
Austin
ops:
Originally Posted by Zodiac R279
Very nice What was your Base line about when you started modding?
here is the plot vs. the current plot, as you can see I had issues with the RPM signal
http://www.imagestation.com/picture/...e.jpg.orig.jpg
Austin
