Post Your Tuning Tips
Old May 20, 2003 | 03:20 PM
e r i c s 9 9 s i's Avatar
e r i c s 9 9 s i
What are your tuning stratagies? Where do you start? What do you adjust first? I know you begin with everything set at factory spec.
Post up your tuned numbers and whats done to your motor? What are your settings set at (Fuel Pressure, Cam Gear Settings, Distributor Timings, VTEC engaugement, etc..)? What tuning devices do you personally use (V-AFC, Hondata, ECU swap, etc..)?
Old May 20, 2003 | 07:25 PM
Jan Niemi's Avatar
Jan Niemi
I think the best tuning for me is done at the dragstrip, when I MPH high, I know I'm making power. Stock distributor timing (static), the ignition timing is at the will of the vafc (don't like it but all I can afford right now)
I like to have real-world results for my tuning efforts, dyno numbers don't mean that you have a fast car. Refer to USCC ITR making 380whp, running 13s.
Old May 22, 2003 | 10:21 AM
B2FiNiTY's Avatar
B2FiNiTY
First, you can start with ignition timing. Play with the distributer and see what the car likes.
Next, even out the a/f ratio.
Then play with the cam gears.
vtec adjustment
Rinse and repeat.
Old May 22, 2003 | 03:16 PM
Trey
Guest
Posts: n/a
Hondata actually suggests set the AFR then do Timing.
Then cam gears.
I really suggest checking these out.
http://www.itrca.com/FAQ/tuning/
