Suspension Tech Rear sway with lower tie bar? 98 Ex
Hater
Is anyone with 96-00 Ex running a suspension tech rear sway with a lower tie bar? I wanted to know cuz the company said that with this particular bar, you can't and I wanted some opinions. I'd hate to see my friend's rear subframe rip apart, and I was looking into a Beaks or Beaks type kit. TIA.
Just another import lover
I installed my suspension tech front and rear sway myself. I ran into a few minor difficulties apart from a little necessary drilling you have to do for bolt holes. Make sure to use the template that comes with the install kit. It might take a little while to line everything up correctly but DO THIS RIGHT!!! :thumbup:
I had to remove my lower rear tie bar because it was in the way of the sway bar. It has to be removed in order to complete the install. you really don't need it if you have a sway so don't worry about getting rid of it.
dnt94civic
04-05-2003 09:45 AM
Gusto222
01-05-2003 01:31 PM
Unjockable
92+ Civic/EL & Del Sol
6
01-04-2003 12:16 AM
