Q on P/S with B16A swap
Old Mar 17, 2004 | 09:47 AM
incublinkus's Avatar
incublinkus
JDM Fan Boy
Default Q on P/S with B16A swap
what power steering pump and bracket do i need? are all B-series power steering brackets the same? what about B-series pumps? can i adapt anyone one of them to my setup?
Old Mar 17, 2004 | 10:03 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You will need a Bseries bracket. They are the same.
You can use a Civic pump, but it only mounts with one bolt and you can't use the adjuster.
If you do use a teg pump, you need to get a teg ps line and have the end cut off to mount onto your civic line because the end of the ps line that connects near your firewall has a different bend in it than your civic one and it doesn't connect correctly because of that bend.
I had the ends that connect to the pump swapped over so I could use the teg end on the pump, but the civic end near the firewall.
slow_a$$_eg
Engine Swaps, Tech & Tuning
17
Oct 11, 2006 07:02 PM
CivicSiR7
Feb 8, 2004 08:08 PM
894drsleeper
CRX & Pre 92 Civic
Apr 14, 2003 01:56 PM
Outlawedracing
Apr 12, 2003 08:26 AM
