I'm very close to be CRAZY
Old Mar 9, 2004 | 03:30 PM
Dariusz's Avatar
Dariusz
Default I'm very close to be CRAZY
I have 2 months fighting with a ECU error #9 in a P72 B18C1 with Hondata. I know that the error #9 is the No. 1 Cylinder Position (CYP).
I make all the manual troubleshuting, cut the hondata jumper (return to OEM), n-check the ground wires, change the distributor with other car, change the ECU, etc, etc, etc and the code remain. I lost my time and mind with this problem...
The car have good iddle, start good, I dont have clue with this.
PLEASE HELP, ALL IDEAS ARE WELCOME
Thanks in advance,
Dariusz
Old Mar 10, 2004 | 11:31 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
it sounds like the obvious, (cyp) sensor
Old Mar 11, 2004 | 10:51 AM
Dariusz's Avatar
Dariusz
As you can read in my post, the ECU and the Distributor is changed (the CYP sensor is inside the Distributor).
Old Mar 11, 2004 | 11:23 AM
Daniel's Avatar
Daniel
Copied to Engine Tech were some awesome gear heads may be able to help! :thumbup:
Old Mar 11, 2004 | 02:23 PM
ludeboom's Avatar
ludeboom
are you able to verify continuity and solid connection on that part of your engine harness? no idea which wires since its a gsr motor...i do H...but the helms should have wire colors.
maybe some more history on the car and what was done to it.
~boom
Old Mar 11, 2004 | 06:06 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Dariusz
Only time i've ever had that code consistantly was when my cams were misaligned. Have you done any work on the engine that requires timing belt removal lately?
hueman
Jun 5, 2003 12:22 AM
niko
92+ Civic/EL & Del Sol
19
May 14, 2003 12:12 PM
slammmedintegra
10
Oct 9, 2002 06:58 PM
BigFatSandwich
12
Oct 9, 2002 01:18 AM
HatchVX
10
Oct 8, 2002 02:04 AM
