Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Engine Swaps, Tech & Tuning (https://www.honda-acura.net/forums/engine-swaps-tech-and-tuning-33/)
-   -   I'm very close to be CRAZY (https://www.honda-acura.net/forums/engine-swaps-tech-and-tuning/128197-im-very-close-to-be-crazy.html)
Dariusz Mar 9, 2004 03:30 PM
I have 2 months fighting with a ECU error #9 in a P72 B18C1 with Hondata. I know that the error #9 is the No. 1 Cylinder Position (CYP).
I make all the manual troubleshuting, cut the hondata jumper (return to OEM), n-check the ground wires, change the distributor with other car, change the ECU, etc, etc, etc and the code remain. I lost my time and mind with this problem...
The car have good iddle, start good, I dont have clue with this.
PLEASE HELP, ALL IDEAS ARE WELCOME
Thanks in advance,
Dariusz
hondatech Mar 10, 2004 11:31 AM
it sounds like the obvious, (cyp) sensor
Dariusz Mar 11, 2004 10:51 AM
As you can read in my post, the ECU and the Distributor is changed (the CYP sensor is inside the Distributor).
Daniel Mar 11, 2004 11:23 AM
Copied to Engine Tech were some awesome gear heads may be able to help! :thumbup:
ludeboom Mar 11, 2004 02:23 PM
are you able to verify continuity and solid connection on that part of your engine harness? no idea which wires since its a gsr motor...i do H...but the helms should have wire colors.
maybe some more history on the car and what was done to it.
~boom
Speed Phreak Mar 11, 2004 06:06 PM
Dariusz
Only time i've ever had that code consistantly was when my cams were misaligned. Have you done any work on the engine that requires timing belt removal lately?
© 2026 MH Sub I, LLC dba Internet Brands
