Terrible brake noise
Old Mar 9, 2004 | 11:14 AM
timmyh's Avatar
timmyh
From: Wisconsin Dells, Madison, Whitewater, all in WI
Default Terrible brake noise
This will be a little vague, but i'm hoping someone may know what's going on. I have this horrible crunching noise, sounds almost like metal on metal just grinding together, from my left front brake. I've taken it to midas several times, but to no avail. The rotors are brand new one month ago (the sound has been there since summer) and the pads are, and i quote mr. midas "high-quality ceramics with A LOT of life left." The noise is only when braking, and due to it's nature of making the noise rapidly then slowing down with speed, we thought it was the rotor, but as i said new rotors didn't help. And it ALWAYS makes a crunch as i come to a complete stop. Any help welcome.
Old Mar 9, 2004 | 11:47 AM
lttletimmy's Avatar
lttletimmy
It sounds like your caliper might be dragging. Check the rotors yourself, both sides, to see if they look alright and not eaten up. Other than that the only thing that pops into mind is that you didn't put any anti-squeal compound on there when you installed the pads
Old Mar 9, 2004 | 01:58 PM
Spec R's Avatar
Spec R
check the guide pins on the calipers. if they get stuck because of lack of lubrication only the inboard pads get pressed against the rotor during braking and the outboard pad doesnt do squat because the caliper cannot properly "float" or slide.
DB Squad
Integra Forum Moderator
Old Mar 9, 2004 | 05:07 PM
Kai's Avatar
Kai
Rotorphile.
The last time I ever had the brakes making a grinding noise years ago, one had cracked from being worn to thin and the cracked edge was grinding into the rotor. Two new rotors and a set of front pads later, I learned the valuable lesson of checking my damn brakes once in a while.
Old Mar 9, 2004 | 07:07 PM
ISP James's Avatar
ISP James
DAMIMRED
well if midas didnt find a problem you probably dont have anything too serious or they woulda bent you over and stuck one to ya
Old Mar 10, 2004 | 07:24 AM
bstrieter's Avatar
bstrieter
Default brake noise
My '98 integra LS had a similar problem, even with new disc and pads. It was the metal retainer clips for the pads. One retainer clip was rubbing against the outside edge of the disc making the noise. It took me a while to discover the problem.
I was able to get the clip to not rub the disc by using a flat srewdrive and leveraging the clip away from the disk, by inserting the scrwedriver between the disk and the retainer. It sounds stupid, but I have not had the problem since doing this 6 months ago.
LX4CYL
Accord
18
Aug 13, 2006 06:31 PM
Dub2045
92+ Civic/EL & Del Sol
10
Jul 12, 2003 08:25 PM
SilverMPower
CRX & Pre 92 Civic
4
Jan 30, 2003 04:28 PM
bokchoyboi
3
Oct 21, 2002 08:18 PM
