B16A2 problem..
Old Feb 20, 2004 | 01:20 PM
loodboi's Avatar
loodboi
هونده بريلود
Default B16A2 problem..
I found an B16A2 motor in mint condition, but there is one problem..Usually B16A2's redline are on 8200rpm. This motor doesnt do more than 6500rpm, what do you guys think is the problem? Is this a ECU problem? Please help!
Thank you
Old Feb 20, 2004 | 03:25 PM
ludeboom's Avatar
ludeboom
Thank you
u r gonna have to give a lot more info than that guy
like what vehicle its in (si or swapped)
MIL lights?
just give a brief description of the situation with technical details.
my h22 would redline at 6500 whenever my air filter fell off the end of the pipe (goddamn ebay shit), i eventually got a AEM to fix that problem.
~boom
Old Feb 21, 2004 | 12:10 AM
loodboi's Avatar
loodboi
هونده بريلود
Its not swapped, its from factory in the Civic VTi (EG9). It have 130,000km on it. Do it make sense if the motor were stock or if there was some other cam's..and other motor trims..?
Old Feb 21, 2004 | 11:38 AM
qtiger's Avatar
qtiger
Does it feel like a redline (abrupt stop, jerky, etc), or like the engine just can't make it any higher?
Old Feb 21, 2004 | 02:19 PM
loodboi's Avatar
loodboi
هونده بريلود
I will ask him everything, i didnt test drive it.
Old Feb 23, 2004 | 03:18 AM
loodboi's Avatar
loodboi
هونده بريلود
I asked him, he said..
He didnt drive it up to 8200rpm too much, he drove it nice and gently. But the thing happened when he changed the stock cam's to enem cam's. And its exactly like a usual redline, but at 6500rpm instead of 8200rpm.
What is this weird problem!?
Old Feb 23, 2004 | 08:53 AM
ludeboom's Avatar
ludeboom
sounds like his timing may be advanced too far.
most likely when he put his distributor back on he advanced it by mistake.
another possibility is that the cams were not installed correctly and the sprockets are incorrect by a tooth or two on the timing belt.
~boom
Old Feb 23, 2004 | 12:36 PM
Nelson's Avatar
Nelson
Administrator
What ECU is he using.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Feb 27, 2004 | 01:36 AM
loodboi's Avatar
loodboi
هونده بريلود
The stock VTi ECU box. (VTi = EDM B16A2 Civic)
Old Feb 27, 2004 | 06:35 AM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Make sure he doesn't have any codes. ON certain codes the ECU will never let VTEC enguage and the redline will be around 6500-ish.
