Check engine light?
Old Jul 31, 2002 | 11:41 AM
Dcivicdan's Avatar
Dcivicdan
GoFast>>>>>>>
Default Check engine light?
My check engine light came on the other day and it hasnt shut off.
There is nothing wrong with the performance of my car though.
does anybody know what may be the problem. How to fix it.
Thanks in advance!!
Old Jul 31, 2002 | 11:52 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Find out what code it's throwing and go from there.
http://www.c-speedracing.com/faq/06.html
Old Jul 31, 2002 | 02:41 PM
Dcivicdan's Avatar
Dcivicdan
GoFast>>>>>>>
how do I check the code??
Old Jul 31, 2002 | 03:09 PM
kinghawk's Avatar
kinghawk
Man look at the link inspyral supplied you
Old Jul 31, 2002 | 03:44 PM
Dcivicdan's Avatar
Dcivicdan
GoFast>>>>>>>
it says that page cannot be displayed!!
Old Jul 31, 2002 | 04:27 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Comes up fine for me... :dunno:
-Harry
AIM: NDcissive
Old Jul 31, 2002 | 05:18 PM
kinghawk's Avatar
kinghawk
Works for me !!!!!!!!!!!
Old Jul 31, 2002 | 09:50 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
CHECKING THE ECU CODES
If your CEL has illuminated, it is more helpful to know WHY it has lit up instead of just guessing at the problem... How do you find out what the error is? Well you will need a short peice of wire or a paperclip.
On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires.
That you need to do is turn the ignition off, and using the piece of wire or paperclip, jump the blue connector so that you connect the two wires together. Basically stick one end of the paperclip or peice of wire into one prong on the connector and stick the other end of the paperclip or wire into the other prong.
Once you have done this, turn the key to the IGN position and watch your CEL light. It will illuminate in a series of flashes.
You will notice that there will be LONG flashes and SHORT flashes. All of the ECU trouble codes are two-digits. LONG flashes determine the TENS digit by the number of times it flashes, and SHORT flashes determine the ONES digit by the number of times it flashes.
ie. LONG-LONG-LONG-SHORT-SHORT-SHORT-SHORT-PAUSE
is the trouble code: 34
3 LONG flashes followed by 4 short flashes, then a long pause. If that is the only code the ECU is throwing, then the code will simply repeat until you remove the key. If, however there are more than one ECU error code, then you will see a different series of flashes followed by the long pause. Once all the ECU codes have been displayed, they will continuously cycle until you remove the key.
ie. LONG-LONG-SHORT-PAUSE-LONG-LONG-LONG-LONG-SHORT-SHORT-SHORT-PAUSE
is the trouble code: 21 and 43
Once you have determined the codes, you can simply remove the paperclip or wire from the connector and replace it back in the green housing.
So now you have the codes, what good are the numbers? What do they mean? Refer to the TROUBLE CODES section.
Old Feb 11, 2006 | 01:00 PM
95LSv's Avatar
95LSv
Banded
I did just this today and it did not work? Any reasons? (i used a paperclip)
Old Feb 14, 2006 | 10:30 AM
flyerhky11's Avatar
flyerhky11
My CEL is on, but is only on after the car is driven several miles. Will this paperclip test work even if the CEL is not on? Should I do it while the car is running since the light goes away after the car is off and only appears once I drive a little? Thanks
