GSR fuel pump Vs. Civic Fuel pump
Old Feb 8, 2004 | 06:55 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default GSR fuel pump Vs. Civic Fuel pump
What is the flow difference between the two?? Would a GSR pump help run a Z6 with some mods run better? Thanks for the help.
Old Feb 8, 2004 | 06:57 AM
honura's Avatar
honura
Seni
Im not 100% sure but I know if you wanna get more gas flow and IF the gsr does flow better it will not do anything for you due to the injectors being the same size . You will need to get bigger injectors as well . Goodluck !
Old Feb 8, 2004 | 10:53 AM
EJcivic02's Avatar
EJcivic02
I talk Before I think
IF i were you, id upgrade the fuel pump. Its not a necessity, but it will help. The D series fuel pumps flow less than the GSR/TypeR/B16 pumps. There have been some guys that had problems with bogging due to not enough fuel being delivered, so they upgraded to a higher flowing and solved to problem to an extent. HIH
Old Feb 8, 2004 | 01:49 PM
dantastic's Avatar
dantastic
cx power!
stock civic pumps (non twin cam) and teg LS pumps are said to flow ~79lph. dohc vtec pumps are said to flow 135 lph
Old Feb 8, 2004 | 02:11 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
i wouldn't replace it unless youre concerned that its acting funny or getting old. Otherwise, the stock one will be fine.
Old Feb 8, 2004 | 04:47 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Approx 165k miles on a stock CX pump and it ran a '95 B18C1 just fine. I think most people who benefit from upgrading to a GS-R pump from a Civic one only see a difference because the Civic pump was on it's way out. I haven't seen any solid data (IE factory specifications or actual flow tests) that the fuel pump in cars with DOHC VTEC cars are any different from every other Civic/Integra. It seems to be a pretty common assumption (and logically following what's usually done with those cars) but I haven't seen any data proving those pumps are more efficent. If your concerned about your fuel setup, an adjustable fuel pressure regulator or something like a V-AFC might be a wise investment if you have access to a dyno to tune with.
By the way, nice sig white n slow, I just noticed that.
Old Feb 9, 2004 | 10:50 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
no it wouldn't i ran the stock EX fuel pump pushing 450CC injectors on 10 pounds of precision SC50 boost.
Old Feb 9, 2004 | 11:15 AM
HatchVX's Avatar
HatchVX
I got the pump with the car. I was just wodering. thanks for all the replies :thumpup:
Old Feb 10, 2004 | 12:05 PM
EGteknikhatch's Avatar
EGteknikhatch
Team Teknik
The stock CX pump is running my 98 GSR. THe stock pump is good up to 200 hp...
Old Feb 10, 2004 | 10:43 PM
drew935's Avatar
drew935
Laguna Seca circuit
I installed the ITR stock fuel pump. Works fine and drinks gas on tap like it should.
CTRJoe
Mar 30, 2004 07:43 AM
blkdragteg63
Engine Swaps, Tech & Tuning
19
Apr 19, 2003 09:11 AM
97 CIVIC EX
92+ Civic/EL & Del Sol
5
Feb 26, 2003 02:22 AM
hyperlite
7
Jan 29, 2003 08:19 PM
jaje
News & Rumors Archives
17
Jun 27, 2002 03:16 AM
