Alignment results after Tein Stech install
Well, I decided Id post the alignment results I got about a week ago after I installed my Tein STech lowering springs. My camber in the front is barely off in the front, within spec on one side and .2 degrees out of spec on the other side. On the rear the camber is a bit worse, one side is .1 degrees out of spec and the other .8 degrees out of spec, which isnt great, but I dont think it will be too bad. My toe is set to spec now, so I really should be fine, the alignment guy said I dont need a camber kit, which was what I was thinking anyway. Heres the chart just for reference:
your fronts look pretty much in spec.
the rears just need 1 or 2 washers
h:
