Turbo Timer.?
Old Feb 1, 2004 | 11:41 AM
SlowRider's Avatar
SlowRider
Default Turbo Timer.?
Hi. Yes one more dumb question from me..A friend of mine has a Celica with a large nitrous setup. He is using a turbo timer. But he doent have a turbo. I asked him why and he said that after he runs the car real hard with the nitrous or just real hard in general it is better if you let the car have some idle time to cool itself down. Is this true is it ok to have a turbo timer without a turbo or is it just a waste of a turbo timer??
Old Feb 1, 2004 | 12:07 PM
Kestrel's Avatar
Kestrel
Push to shock!
I always thought a turbo timer was just so that the engine will idle for a while after the ignition is shut off so that oil and coolant can circulate to a turbo to prevent oil from coking. I don't know if it has any additional benefits in cooling the block.
Old Feb 1, 2004 | 02:39 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
:thumbup:
Exactly.
Slowrider: Bitch slap your friend, he could just sit in his car for a minute and let it cool down.
Old Feb 1, 2004 | 06:45 PM
SRT_Andy's Avatar
SRT_Andy
Turbo timers are for lazy people. Just ask WCS! HA HA HA! I have to harass him about that.....
Old Feb 1, 2004 | 06:50 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:rick:
Hey, it's very convenient. h:
It's not a horrible idea if he is running N2O. I don't expect his car to last that long if he's running it so hard that he thinks he needs a turbo timer, but hey.... it's another gadget right? :chuckles:
Old Feb 1, 2004 | 06:52 PM
SRT_Andy's Avatar
SRT_Andy
Just a thought: why would he need to cool the motor when nitrous does just that? Ever heard of someone freezing a piston from too much juice?? Just wondering......
Old Feb 1, 2004 | 07:08 PM
westcoaststyle
it depends on the use.
If it's a direct port kit, it's not made to cool the air, it's made to create a larger/hotter explosion in the cumbustion chamber due to the cumbustability of N2O.
If it's used as a fogger kit, then yes, it's just cooling the air off a LOT before it hits the cylinders.
Old Feb 1, 2004 | 07:11 PM
SRT_Andy's Avatar
SRT_Andy
Wow, I thought that it made cooler temperatures no matter which form it was used in. See, I learn something every day
http://www.howstuffworks.com/question259.htm
Old Feb 1, 2004 | 08:37 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
yeah, if you have too much n2o and not enough fuel it burns really hot. thats the most common cause for nitrous-related engine damage, and the primary reason why a wet setup is better than a dry one.
Old Feb 2, 2004 | 03:28 AM
SRT_Andy's Avatar
SRT_Andy
So, basically you're saying that if the N2O and fuel are mixed correctly, it will burn at a cooler temperature?
