Ording wheels soon. Help me!
i have a 95 cx hatch and i know the i can fit 17x7 with a 4x100 bolt pattern, but im not sure what the offset should be any help? I have neuspeed race springs also! Thanks
-Rich
-Rich
Wheel offset defined: http://www.tirerack.com/wheels/tech/offset.htm
I never have figured out what exactly my drop is. It's been like 4 years since I was at stock height. :dunno:
My 16x7" wheels has a +37mm offset and when I was using 205/40/16 tires, I didn't have to worry about rubbing at all (no matter what the height the car was). When I switched to 205/45/16, I'd experience minimal rubbing on the fenderwell.
When I used to have 18x7.5" with a +40mm offset with 215/35/18's, I could hardly lower it. I was driving with about an inch gap between the tire and the fender and I would rub hitting dips and whatnot.
So if you could get an offset between 42-45, you should be gravy.
