Battery keeps draining overnight
my bum is on the swedish!
:upset:
Originally, tests showed the first battery I had to be fine. I replaced it anyways. 3 days later, the new battery is doing the same thing as the old one.
the alternator is fine.
I only draw 400w max or so with two amps, so I don't think its a problem of over-draw.
There's a questionalble main ground wire connection, but other than that, the stereo wiring is fine (I don't have a metal drill bit
h: ). Still, I don't see how a ground wire would be draining my battery. Oh, and no amps are staying on overnight. They both shut off with the HU.
I've pulled the following things for a night with no change in outcomes: Alarm, main stereo fuse, etc.
however, when I exit my car, I get shocked.....
anyone have any ideas? I'm running out
h: ). Still, I don't see how a ground wire would be draining my battery. Oh, and no amps are staying on overnight. They both shut off with the HU.I've pulled the following things for a night with no change in outcomes: Alarm, main stereo fuse, etc.
Well Theres deff a short somewhere in the car ! My coupe had the same problem . it was a bit of water getting into the fuse box and every f**cking time I get out of my car it would give me a little shock . Take a look at ever wire that you can possibly see something is shorted out !
Originally Posted by honura
YEah I know but its better then dissconecting your batt everytime you go home !
even still, I like an alarm, so no to the battery disconnection.....
Originally Posted by b16aEGcivic
if you have a system check where your amp wire goes through the firewall...mine woar through the coatin and started grounding out and my battery would drain
I dunno, in about 3 minutes, I'm gonna look over it again.... damn drizzle.... :a:
well, just got back from a stereo shop.
they said everything was cool with the stereo, and it wasn't that.
even with the system unplugged, the alarm removed, and everything off, it would still drain :angry:
the only suggestions they could come up with were either to take it to the stealership and have them look at it ($$$$), or to remove the battery terminals and watch it with a multimeter, which, at this time, I'm currently doing.
sigh.......
ANY suggestions would kick ass
sigh.......
:thinking: interesting. Maybe its the battery that cant hold a charge? Try taking the battery to a Batteries Plus or something and having it checked.:dunno: Hope it works out for ya buddy
probably gonna end up parking it in the garage tonight with the terminals off. I'll see how that holds. Hopefully, the battery will die again on its own.
if it doesn't, and starts like normal tomorrow, I'm ****ed
