CTR cams VS Skunk 2 cams.
Old Jan 25, 2004 | 05:48 PM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Default CTR cams VS Skunk 2 cams.
Friend has a b18 swap in his 2000 civic. I believe it's a GSR engine from a 94 model?
He want's to change the cams but decided to go with the CTR cams instead of the Skunk 2 cams. He was told that the CTR was a better choice because it was OEM with the valve train...and since Skunk 2 is after market you need more modifications to get more potential out of them.
I'm just curious to as why? Or did I just answer my own question? And what kind of other MODs would have to be done to squeeze the full potential of the Skunk 2 cams...
Old Jan 25, 2004 | 06:48 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Which stage skunk 2's? Stage 1's are made to work with stock valve train. With stage 2's you are supposed to upgrade, and more compression is needed to get the most out of them.
Old Jan 25, 2004 | 06:56 PM
YeaItsAFourDoor
He didn't mention what stage...but gave the same you did about the compression...so possible the stage 2..
Old Jan 25, 2004 | 06:59 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Even without the compression i would take the stage 2's over the ctrs anyday. On stock compression they make good power and with more compression they make even better power. Either way they are the best choice.
Old Jan 25, 2004 | 08:38 PM
Civic2Scooby's Avatar
Civic2Scooby
you should really upgrade the valve train with the CTR cams as well, if you want to use them to there full potential.
b16a_integra
Engine Swaps, Tech & Tuning
4
Nov 15, 2002 06:03 PM
lilbrownplayer
Nov 4, 2002 01:53 PM
insnimprtguy
9
Oct 7, 2002 09:22 PM
MoFo
3
Sep 8, 2002 09:40 AM
IDohcVtecExI
3
Aug 20, 2002 12:52 AM
