Camber
A while back I was readng this tech thing about fixing your rear camber without a kit. Basically, all you do is take the bolts that bolt your trailing arm to your chassis, get bolts that R a little longer, and put washers in there 2 space it out. If you know what I'm talking about, what size bolts and washers do I need?
Materials:
• 4- 10mm- 1.25 x 35mm hex bolts
• 20-24- 3/8" stainless steel flat washers (5-6 per bolt)
• Strong screwdriver
• Socket wrench with 9/16" and 11/16" sockets
• Long extension for socket wrench
• Jack (and jackstand recommended)
Original Author: Troy icarus25@aol.com
here is the linky.
here is the linky.
If it's not bad, do what I did. Just throw one washer behind each bolt, and throw it back together. Took 5-10 minutes a side, and it's almost perfect. I think I'm 1 degree beyond spec. I can handle that.
integra-boy
8
Jul 31, 2002 12:14 PM
