Suspension Techniques Sway Bars
:boink:
Just got them today after waiting 3 weeks (no props to Top End Motorsports at all :madfawk: ) I was wondering how hard they were to install on a civic coupe without a factory sway bar...:dunno:
any tips for the install would be great too......
:idb:
Best advice I can give, follow instructions. I don't know how much you know about suspenion, so I will also suggest installing the rear only because with both bars you will be right back where you started, understeer. With the larger bar on the rear you will increase oversteer either making the car neutral or a tad bit of oversteer. On my own car, I use an ST adjustable rear sway with the stock front sway - shortened end links & poly bushings. Lower rear tie bars are also highly suggested to prevent frame tear-out, which large rear sways are known to do with little civics. There is also a beaks frame reinforcment kit.
