need some help here guys
i have a 97 civic dx hb.... i just bought a front clip from a 2000 si. how hard is it to change the entire dash over to my 97? i don't want to chop up the si wiring. i want it to look factory stock. is it a unbolt and unplug swap? also...when i swap the motors...do i need the fuel pump from the si? also...anything else that i need please let me know..
lucky you..
most of the stuff will just transfer over, I doubt you'll really need to wire anything up differently as long as your car is manual..everything should just plug and play (minus tachometer from SI cluster)...don't quote me though
Originally posted by honura
Yeah everything will plug and play ! The whole thing ! and no you do not need the fuel pump but I guess its a plus to slap it in if you have it . Good luck and happy you !
