Governor?
Old Jan 21, 2004 | 09:37 AM
94CIVICDX's Avatar
94CIVICDX
Default Governor?
Hi. Is there anyway to remove the Governor in a D15b7 and what about the rev limit.?
Old Jan 21, 2004 | 10:11 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i dont think there is a "governor".....the rev limiter is programed into the ecu and i think u might be able to change it with some tuning......correct me if im wrong
Old Jan 21, 2004 | 10:16 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
yes there is a governor, my civic tops out at 125 but i dont think u would want to go any faster than 125 in a civic with limited mods
Old Jan 21, 2004 | 10:23 AM
Hondaman's Avatar
Hondaman
Black Pearl
The rev limiter is there for your protection. Don't get rid of it, that's just asking for trouble.
Old Jan 21, 2004 | 10:28 AM
NoRiCeHeRe's Avatar
NoRiCeHeRe
:werd: There is no use to either of changing the rev limit or bypassing the govenor. :slap: They put them there for a reason.
Old Jan 21, 2004 | 10:33 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
yea my friend had a 00 si and he removed the rev limiter and he accidentally downshifted into 2nd on the highway and he shot a piston through the hood
Old Jan 21, 2004 | 11:11 AM
honura's Avatar
honura
Seni
Yeah I mean I could understand you wanted to remove that on your b16 + motors but a d15 ? It's not gonna help you one bit . I just got a 92 Hb and that shit is killer slow ! Do you know how hard it is to cut someone off ? :madfawk: But hey either way if you do remove them your still in the same spot . YOU HAVE A SHITTY MOTOR ! LEARN TO COPE WITH IT ! Not trying to be an ass**le about it
Old Jan 21, 2004 | 12:57 PM
Kestrel's Avatar
Kestrel
Push to shock!
I believe that's a drag limited speed, not a governor speed.
A rev limiter won't save you then. The car is moving so fast that it forces the engine to spin really fast, and the engine will still blow. All the rev limiter does is cut fuel after a certain RPM.
Old Jan 21, 2004 | 01:25 PM
94CIVICDX's Avatar
94CIVICDX
Any engine can be fast. I dont have to cope with it because there are milions of things to do about it. Sounds like you need to do some more research. I am not trying to sound like a ass either but a motor is a motor put some time and cash in it and it is capable of doing whatever you tell it to.. My D15 isnt slow and if you want yours to be faster maybe you should think about allitle time and some NOS...Dont worry with the right amout of new shit your car is perfectly capable of whatever..I put a zex kit on mine and I havent a problem...Gueass you will have to try harder.
Old Jan 21, 2004 | 01:43 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
What do you run in the 1/4?
There is a fuel cut at a certain speed, it's not drag. It will cut you at ~125-127 mph. Why would you need to go faster than that?
