o2 Sensor
My friend had and HX engine with a 5-wire o2 sensor and we swapped in a JDM GSR with a 4-wire sensor. We can't get the CEL to go away and we were wondering how you need to wire it up to get the CEL to stop popping up.
Originally posted by wambamcivic
yeah we used the stock HX harness
Go into a dealership and ask if you can look at their manuals... should tell you what pins are what right in there.
Originally posted by import-tooner
Have you checked to see what code the ecu is throwing? or is that where you came up with the o2 sensor...
Originally posted by qtiger
I don't have a 92-95 Civic electrical manual, unfortunately.
i have a problem now, just put a new TPS sensor on it, but it idles high in between changing gears, its stays at about 2k then drops down to about 1500 or 1k, im gonna go mess with it 2marrow, does anybody know what it could be?
