Engine Coolant temp. sensor help
Old Jan 10, 2004 | 07:37 PM
hndrcr94's Avatar
hndrcr94
Default Engine Coolant temp. sensor help
I performed a search and nothing came up. Anyway, My car threw a code for the engine coolant temp sensor. My car started idling very weird. It idles at 3 grand cold. When it warms up it fluctuates between 1 and 3 grand constantly. I'm puzzled. Any help would be appreciated.
Old Jan 10, 2004 | 07:58 PM
worleybot's Avatar
worleybot
part time tech
If I remember correctly the ECT sensor does affect your idle because it is used as part of a feedback loop for you IAC valve. So if your ECT is a constant high (which would indicate low temp) or a constant low (indicating high temp) or fluctuating then your IAC wouldn't know what to do. There are some tests you can do with a digital multimeter but you would have to look at a chiltons since I can't remember what they are right off hand. Hope this helps.
Old Jan 10, 2004 | 08:02 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Well, if the ECU can't tell what temperature the engine is at, then it wont be able to properly adjust the air/fuel ratios, RPM, and the automatic choke...
Time to crack out a manual and see if you're up for the task!
Old Jan 11, 2004 | 07:18 PM
hndrcr94's Avatar
hndrcr94
I changed the sensor and nothing happened. I think i have narrowed it down to the fast idle thermo valve or the iacv.
Old Jan 11, 2004 | 07:36 PM
99DCtwo's Avatar
99DCtwo
a bad Air Idle control sensor general stays revved up all the time. It is also a pretty expensive sensor! did you eve get that surge from your spacer figured out coud still be a vacuum problem!
