Installation of original camshafts Integra Type R on Civic SI (B16A2)
Old Jan 9, 2004 | 04:46 AM
jp184's Avatar
jp184
Default Installation of original camshafts Integra Type R on Civic SI (B16A2)
when we change the camshafts, is it obligatorily necessary to change the Valve Springs?
let us must change Adjustable Cam Gears or it is already well regulated ?
I want to make economic and reliable.
Thanks
Old Jan 9, 2004 | 02:40 PM
Kai's Avatar
Kai
Rotorphile.
It depends on how aggressive the cams are. For Type-R spec cams, you can usually get away with stock springs. Don't forget though, weak springs cause valve float, and valve float can easily destroy the engine.
Cam gears are nice, but far from required.
Old Jan 12, 2004 | 05:36 AM
jp184's Avatar
jp184
thank you, I will buy camshafts of ITR, after, I will change the springs because I have a ECU 4800/9000.
Old Jan 12, 2004 | 05:38 AM
Kai's Avatar
Kai
Rotorphile.
I hope you don't actually plan to rev to 9k.
Old Feb 12, 2004 | 07:00 AM
jp184's Avatar
jp184
What do you think of INNER STIFFER VALVE SPRINGS to add to my springs? Is less expensive than news specials springs (88$ per 16)
Thank
JP
PS: in this moment it goes up easily to 8800
Old Feb 15, 2004 | 08:59 PM
Asahi's Avatar
Asahi
Administrator
9k is fine on a Stock Type-R Valvetrain as long as he changes to that. Not sure I'd try it on an SI setup
Old Feb 16, 2004 | 01:16 AM
Snoopy's Avatar
Snoopy
been there done that
itr cams wont make power that high so revving to there is pointless
Old Feb 16, 2004 | 01:53 AM
Civic2Scooby's Avatar
Civic2Scooby
:werd:
but I would recomend at least ITR valve springs
Old Feb 16, 2004 | 05:13 AM
Asahi's Avatar
Asahi
Administrator
ITR cams will make power to about 8200 and the drop off is so slight it is worth going to 8900-9000 to drop back in at a higher rpm in the power band. Plus it keeps from needing to shift at some auto-xs
