fuel cut off switch
Old Jan 4, 2004 | 10:33 PM
pbizzlegsr's Avatar
pbizzlegsr
Default fuel cut off switch
i keep reading about getting a fuel cut off switch or wire or something of that sort where your fuel shuts off and its impossible to start the car..its done to prevent cars from getting stolen..where can i get something like this done at? and how much would it cost..also how does it work?..any info thanks
Old Jan 4, 2004 | 10:39 PM
So.Cal_INTEGRA's Avatar
So.Cal_INTEGRA
I think you can only get it if you get a lowjack installed
Old Jan 4, 2004 | 10:55 PM
ant6177's Avatar
ant6177
you might be able to rig some sort of kill switch for the fuel pump, so that it cuts off when you flip it. I read somewhere that people hook this up with their alarms, so that when it goes off the fuel pump is deactivated.
Old Jan 5, 2004 | 01:08 AM
dom93hatch's Avatar
dom93hatch
more meat, more fire
You found the right person for the job! :chuckles:
Ask a lot of the basement posters about my kill switch story. :rofl: I OWN TEH KILL SWITCHERAGES!!!!111~
It's really simple. The only PITA part is removing your back seat. Basically you tap into the wire that comes out of your fuel pump (forgot which one, but there's only 2 so it's either one or the other). Hook it up to a flip switch and that's that. Just find a secret mounting spot and you're set.
Old Jan 5, 2004 | 01:10 AM
dom93hatch's Avatar
dom93hatch
By the way, here's how it works:
Flip the switch on and your fuel pump is active.
Flip it off and your fuel pump sends jack shit to the motor.
No fuel = no start
Old Jan 5, 2004 | 01:11 AM
pbizzlegsr's Avatar
pbizzlegsr
thanks ..do you know the step by step installation?
Old Jan 5, 2004 | 01:22 AM
dom93hatch's Avatar
dom93hatch
Bare with me, I'm quite sleepy...but here's how it goes (roughly):
Take some speaker wire (I used 14 gauge), some crimps, and possibly a drill. Don't forget your flip switch!
Remove your back seat.
That big round metal thing is your fuel pump. There should be 2 wires coming out of it; yellow and black/white. I forgot which one we spliced into, but it's either one of the two...crap, or was it both? I'm not sure if the black/white and the yellow were both tapped into.
Anyhoo, take your wires and crimp them onto the wires from the fuel pump. Run the wires up to your flip switch, and connect one to the 'on' prong and one to the 'off' prong.
That's about it. Find a place to mount your switch, and be sure you have the right amount of wiring to be able to get to that spot.
Put your seats back and you're done.
Gnite....zzzzz
Old Jan 6, 2004 | 04:26 AM
cheezthis's Avatar
cheezthis
sound/acoustical engineer
There's a huge thread in the audio/security/electrical section on team-integra.net on fuel kill switches. It's a "pinned" topic in that forum, so you can't miss it.
