trouble after 75mph
Old Dec 31, 2003 | 09:27 AM
WildRedEye's Avatar
WildRedEye
Default trouble after 75mph
aight, at speeds faster then 75mph my steering gets maddd loose and shaky, it feels like it could lose control @ any minute..
its a 95 GSR/ 2dr/5spd--could it be alignment or the snow tires i put on (i think theyre blizzaks)?
Old Dec 31, 2003 | 11:39 AM
aphex's Avatar
aphex
driftin'
Default Re: trouble after 75mph
:thumbup: my guess is the snow tires, i never drive in snow, but im assuming that your not suppose to go over 75 mph on snow tires
Old Dec 31, 2003 | 12:15 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Most likely the snow tires, cause you're not supposed to go much over 65 in them, if my memory serves me right, but if you're car's fine while maintaining the speed limit, I say drive legally and wait to see if it happens when you put your summer tires back on...
Old Dec 31, 2003 | 01:16 PM
reno96teg's Avatar
speed rating is dependant on the tire. wildredeye, can you tell us the exact tire that you're riding on and the speed rating stamped onto it? i doubt it's even below Q (99mph). i'm thinking you need either a balance, alignment, or both.
Old Dec 31, 2003 | 01:26 PM
g2tegls's Avatar
g2tegls
MR, ftw
Yeah all the winter tires I've driven on (Blizzaks and Alpins) ride fine up to at least 90 although they make a slight whistling noise on wet ground. I would guess alignment or wheel balance as well.
Old Dec 31, 2003 | 01:42 PM
Mac8008's Avatar
Mac8008
Jack up your car and check your suspension components. Sounds like you have symptoms of bad tie rod ends.
Old Dec 31, 2003 | 08:46 PM
IntegraR's Avatar
IntegraR
you ever crashed that car ??? i had someone that crashed his car did the same thing after repair... I dunno i think it it is the tires or you have bend rims (which is 1% posible)
Old Jan 1, 2004 | 12:33 AM
axhammer's Avatar
axhammer
Canadian Icelander
Bend rim, or bad balanced tyres, check ur tire psi. Speed rating of the tyres wouldn't do that, i got winter tyres and do 180km/h on them often.
