F22 DOHC JDM MOTOR In a crx
Old Jul 27, 2002 | 07:13 PM
KingPin's Avatar
KingPin
Banned
Default F22 DOHC JDM MOTOR In a crx
Does anyone know if this is a good idea? What are the specs on a f22 dohc jdm motor and how much would one of those motors cost?
I found a good deal on a crx h/f with a clean title and this kind of motor swap done. Do you think it is worth it for a g of 1500?
Old Jul 28, 2002 | 01:54 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
F22 requires the same PITA hack job as the H-series bigger brother in a 4th gen and previous civic/crx base. Not recommended if it's ever going to be on the street.
-Harry
AIM: NDcissive
Old Jul 29, 2002 | 09:09 AM
KingPin's Avatar
KingPin
Banned
Do you know how much power the f22 motor has? And would the crx be mostly for drag do you think?
Old Jul 29, 2002 | 12:41 PM
1stGenCRXer
Again, hack job. H22 will still have more power, but will also be a hack job. A built drag B20Vtec engine will make as much power as an H22 [which is a hack job] if not more, and weigh less. So back to your original question: Is it a good idea? No. Unless you're gung-ho to build a tube frame front end and save yourself some headache by putting the engine mounts where you want them, then I'm *pretty* sure I answered your question, in which case you can stow the sarcasm.
Old Jul 29, 2002 | 05:48 PM
v4lu3s's Avatar
v4lu3s
jdm f22 is more or less the same as a usdm h23a1
160 hp
Old Jul 30, 2002 | 09:00 AM
KingPin's Avatar
KingPin
Banned
160 hp
Good stuff you's guys, it would be easier to go with a b16a motor or a b18c wouldn't it, no hack jobs with those am I correct?
Old Jul 30, 2002 | 10:04 AM
v4lu3s's Avatar
v4lu3s
those are a LOT easier than the F/H series swaps...
Old Jul 30, 2002 | 02:10 PM
1stGenCRXer
That's a major understatement, but yes, that will be a non-hack job swap
Old Jul 30, 2002 | 03:50 PM
v4lu3s's Avatar
v4lu3s
i dunno the b16a into a crx is pretty srtraight forward with the right mounts and a non obd ecu....
Old Jul 30, 2002 | 04:00 PM
1stGenCRXer
I was referring to your comment that B-series are a lot easier to swap in than F/H series engines. Because it is VERY true.
