Clutch problem
Old Sep 3, 2013 | 07:32 AM
334cobra's Avatar
334cobra
Default Clutch problem
Ok guys...I posted something on this already, and I'm starting to figure this out...just need a little more help.
-car is on ground, not on jack stands
-car is turned ON
-car does not move in gear
Here's the question:
If one of my axles are not in all the way, will I be able to change through every gear without my clutch? Or will it grind even if axles are not in all the way?
Old Sep 3, 2013 | 11:27 AM
334cobra's Avatar
334cobra
Ok, nm I figured out EVERYTHING....wrong clutch disc was included with my clutch kit...how rare is that?! The inner spline part of the disc was too big. So it went right over the input shaft of the tranny, and didn't turn the shaft, cus it was too big for it. How crazy is that?! Pilot bearing and pressure plate fit! too crazy! xD
