does itr cams on a b18 have same effect as ctr cams on a b16
Old Mar 1, 2013 | 05:15 PM
hondaswhirl's Avatar
hondaswhirl
Default does itr cams on a b18 have same effect as ctr cams on a b16
Im eager to hit 200 whp but i dont know whats better for that b18 obviously but im curious to know if the itr cams on a b18 give the same increase as the ctr cams on a b16 or should i for the b18 find aftermarket cams? skunk2? mugen? boex?
and what ecu upgrade or better yet what ecu can i modify for this project the b18/itr cams
Old Mar 18, 2015 | 11:39 AM
EXChris401's Avatar
EXChris401
From what I can remember, is the ctr intake is more aggressive than itr cam. The exhaust cams on itr and ctr are the same. So if you got a b18 and wanna stay oem ctr intake and exhaust. When I had my 97 gsr and did a poor mans itr, I purchased an itr head from the local forums. Itr cams, itr pistons and I couldn't afford a real itr ecu or Hondata. So got a odb 2 to odb 1 conversion harness and got a chipped p28 ecu. That probably affected my hp some. But ran pretty good. If could've gotten an si or itr tranny for the lower gears that would've made a better improvement in acceleration than the gsr tranny.
