itr muffler
Old Jul 19, 2002 | 09:16 AM
lude69's Avatar
lude69
Default itr muffler
will a 97 itr muffler bolt directly onto a 95 ls coupe w/o any modification?
Old Jul 19, 2002 | 09:20 AM
[HrZn]4life's Avatar
[HrZn]4life
I have a 98 itr stock muffler that's bolts perfectly onto my 98 ls....should be cool.
Old Jul 19, 2002 | 09:28 AM
dubcac's Avatar
dubcac
I
Yes, it is an axle back exhaust and will bolt right up.
Old Jul 19, 2002 | 09:29 AM
lude69's Avatar
lude69
did u use u'r stock piping with the itr muffler?
Old Jul 19, 2002 | 09:31 AM
BLUELS97's Avatar
BLUELS97
Without problema. But, think twice if you plan to add or have other mods.
I have a DC 4-1 JDM Header that is 2.5" and the ITR cat-back is 2.25". Now, I want the DC cat-back.
Good luck.
Old Jul 19, 2002 | 03:00 PM
Weston's Avatar
Weston
The ITR and LS mufflers and b-pipes fit the same. So, you can upgrade your LS with a Type-R muffler and/or b-pipe and it will just be a simple bolt-on replacement. I had to bend the heatshield on the underbody a little bit to keep it from hitting the Type-R b-pipe, but that's incredibly easy and I don't think it's a common problem anyways.
Old Jul 19, 2002 | 04:00 PM
lude69's Avatar
lude69
Good luck.
U gonna sell u'r itr catback if u get the DC one? IF so let me know..I'll take it.
Old Jul 19, 2002 | 05:57 PM
Acura2412's Avatar
Acura2412
Does the muffler sound any different or more agressive ?
Or is it a worthless mod???
Old Jul 19, 2002 | 10:32 PM
MikeSarr_GSR's Avatar
MikeSarr_GSR
I have one. I have CTR cams, I was running +2in +4ex for 26 deg of overlap on the GSR muffler and exhaust. I made the most power here. Once I put on the ITR muffler, I was able to run my overlap out to 34 with a slight bump at 4500rpm. Before I tried this with the GSR and it made a valley at 4500rpm and had a dead spot like the car wasnt acclerating until like 5500... I have +4, -2 in the cams now and it made great power at 18BTDC above 6K... not to mention everywhere else. yummy =) This led me to believe that the 98 ITR muffler flows much mo bedda. I like the fact that it is actually quieter than my stock 99 GSR one.
ffslide
Aug 1, 2004 07:45 PM
westcoaststyle
Apr 24, 2003 07:39 PM
b00gers
24
Sep 17, 2002 05:49 PM
frank
92+ Civic/EL & Del Sol
4
Jul 22, 2002 10:00 PM
