Ctr pistons installed on b18c1
Originally posted by Kai
Wow, the compression calculator I use to get rough numbers says that a stock B18C1 with B16B pistons is running around 12:1 compression... you might want to get that tuned ASAP or at least keep it running a little rich until you do.
Ok Its figured out. H22 injectors and high octane gas, feul pressure at 45psi timing at 18 degrees. Thats it thats all you need to run 12-1 compression. Car is running great now, I definately reccomend this mod daily driven or not. I also reccomend getting some cams thats what I am doing next. Forget about the hondata send your ecu to pyr and if you have access to a dyno I highly reccomend using it if not consult your local shop.
Originally posted by SPORTIMAGE
I installed my ctr pistons on my gsr. I got pretty good power gains especially in the higher rpm range at about 5500. I am playing with the timing advances and am later goning to try to find some 100 octane gas. I am very happy with the power but it feels like I could get more from it. I know tuning is going to be a beeeoch but does anybody have any suggestions on how to get it tuned without using a dyno. If any one else has installed ctr pistons your help would be appreciated. Thanks
