H22a swap into.....?
Old Oct 26, 2003 | 06:05 PM
98WhtCivicEx's Avatar
98WhtCivicEx
^^That's Me!^^
Now I have been considering doing an engine swap on my 98 Civic. Is it that much of a hassle. Does it pretty much fit in place or do i have some modifications to fix. H22avid...you were saying there was a problem with the OBD...explain that to me if ya can on what I owuld have to do with that. I figured...instead of spending money on a turbo...get an engine that pushes as much power as my engine prolly would WITH a turbo :-\ Thanks for any replies..
Old Oct 28, 2003 | 08:42 AM
h22avid's Avatar
h22avid
Sleeper...Creeper...
That was for the 4G civic (pre 1992) which is ODB. With yours it is a 6G and you would basically revert from OBDII to OBDI shich is pretty simple from what I've heard. You would need the OBDI motor and ecu and a OBDII to OBDI conversion harness from hasport unless you just get an OBDII H22 which are harder to come by.
Old Nov 7, 2003 | 08:45 AM
Kteller8's Avatar
Kteller8
we put one in my 96 accord, its by far the easiest install.. its just simple lengthen wires, replace ONE mount and drop it.. even trannys out of the accord or prelude fit
Old Nov 7, 2003 | 02:36 PM
h22avid's Avatar
h22avid
I would go with the prelude tranny though, the accords gears are long as shit:thumbup:
Old Nov 10, 2003 | 11:59 AM
scott21's Avatar
scott21
Accord Wagon would be the coolest! SUPER SLEEPER!
Old Nov 12, 2003 | 03:56 PM
accordhybrid's Avatar
accordhybrid
Originally posted by 90tegLS703
i have seen a h22 in 90-93. I guy who work a machine shop in florida did it.. custom mounts, intake manifold and all.. came out real nice..
for the 90-93 swap there are no custome mounts needed you use all accord mounts and brackets.
Accordhybrid
Old Nov 17, 2003 | 03:38 PM
scott21's Avatar
scott21
I thought you needed to shave the Prelude driver side mount to make it fit, but you use only the Accord mounts?
Old Nov 17, 2003 | 05:57 PM
accordhybrid
Thatis only on the 94-97 swaps
Old Nov 20, 2003 | 03:19 PM
scott21's Avatar
scott21
Then what about the 90-93? You just use the Accord mounts? I have a 92 EX and am curious about the possibilities...
Old Nov 21, 2003 | 02:20 PM
sick79's Avatar
sick79
http://members.aol.com/accorddrv/h22.html
try this, i came across it back when i had my 93 accord.
