Plasti-Gage sucks
Old Aug 16, 2003 | 07:47 PM
AwwsChwA's Avatar
AwwsChwA
Default Plasti-Gage sucks
I'm building a D16A6 for my autocross CRX, and I had my first experience with Plasti-Gage checking main bearing clearance. I took two different readings, and got two different clearances. Save your money, just use micrometers to check clearances.
Old Aug 17, 2003 | 06:39 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
wtf is plasti-gage? I use my freind's dad's digital micrometer :thumbup:
Old Aug 19, 2003 | 06:34 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Plasti-gage is this round compressible plastic that you put between surfaces you want to check the clearance on, torque them to spec, then unbolt and match the now-squished plati-gage width to a scale that comes with the stuff to tell you how much clearance those two parts have. The wider the strip, the tighter the fit. Not as common now as it once was, but some old hot-rodders that couldn't afford precision measuring devices "back in the day" swear by the stuff.
-Harry
AIM: NDcissive
Old Aug 19, 2003 | 10:43 AM
white_n_slow
it's my D in a B
hmm. h:
Old Aug 19, 2003 | 11:02 AM
crxb16er's Avatar
crxb16er
i still use the stuff as well as a micrometer, but not digital i use the old fashion machine lathed tools
Old Sep 4, 2003 | 05:01 AM
mysubaruimp's Avatar
mysubaruimp
plasti-gage works very well. you must have done it wrong
Old Sep 14, 2003 | 11:01 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
:werd:
user error owned him:chuckles:
Old Sep 14, 2003 | 07:07 PM
LSVTECKING's Avatar
LSVTECKING
rebuilding
've built numerous engines with plasti-guage and it has never failed me. You must have used it wrong.
Old Sep 21, 2003 | 06:34 AM
agileauto.com's Avatar
agileauto.com
plastigages are the best thing since portable alcohol. hands down. I've been using them for years and NEVER had a mixup. micrometers are cool too but I'm a plastigage kinda guy.
Old Sep 21, 2003 | 11:27 AM
AwwsChwA's Avatar
AwwsChwA
Well, I figured out my error, and got much better readings out of the Plasti-Gage, but I'm still not convinced it's completely accurate. I've checked 3 different oversizes for my rod bearings, and according to the Plasti-Gage, the oversizes are only about .0002" different. Seems a bit small to me.
