Swap into an HX.
Old Aug 31, 2003 | 07:24 AM
imlachg1's Avatar
imlachg1
You guys are great, thanks so much for the good info. Keep it comming if you still got some.
Old Aug 31, 2003 | 07:35 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Originally posted by HXMan
Trick the ECU into thinking there is a fuel tank pressure sensor?
Yes, so you don't throw a code...
-PHiZ
Old Sep 4, 2003 | 12:38 PM
imlachg1's Avatar
imlachg1
I'm looking at spending about 4000-4500 depending on how much my tax return check will be this year. I really want to go turbo. I have two new questions now. I have narrowed it down to the B18b. The question I have is what do I do about the harness. Do you use my stock 00 HX harness, or get the EX harness or the Si harness? Also another question is I won't be doing this swap until Christmas, would it be bad to buy an engine now and let it sit till late Dec. or early Jan (If I can find a good deal)? Thank you very much for all the info you guys have given. All the info has been very helpful.
Old Sep 8, 2003 | 12:56 PM
imlachg1's Avatar
imlachg1
