o2 sensor wiring help
Old Aug 12, 2003 | 12:02 PM
Luis's Avatar
Luis
Civic1.6VTEC
Default o2 sensor wiring help
i bought an aftermarket one. and i need help with the wiring.
the new sensor has a grey, 2 white wired and a black one.
the plug has a green, 2 black wires and a white one.
need help please.
95 Civic D16Z6.
Old Aug 12, 2003 | 03:51 PM
egzivic's Avatar
egzivic
If it came with the plug you shouldn't have to mess with it. If not the manufacturer should have provided some intructions, no?
Old Aug 12, 2003 | 05:38 PM
PHiZ's Avatar
PHiZ
BOOST GOD
http://216.239.53.104/search?q=cache:TXyLHWPUxpMJ:http://www.diy-efi.org/gmecm/ecm_inf...hl=en&ie=UTF-8
A common color coding for heated 02's is:
White pair - heater (12 volts)
Black - signal to ECM
Grey - signal ground (on a 4 wire unit)
-PHiZ
Old Aug 12, 2003 | 06:41 PM
Luis's Avatar
Luis
Civic1.6VTEC
the plug is from the original o2 sensor.
