Idle Question
Old Aug 7, 2003 | 05:07 AM
Carguy's Avatar
Carguy
Default Idle Question
I've just replaced the engine in a 1991 Integra with a used 1.8 out of a wrecking yard. The engine in the Integra had thrown a rod when I got the car, so I don't know how it ran before. The problem I have is that the idle speed constantly varies from about 800 to 1800 rpm. It runs through this cycle about every 3-5 seconds. Any ideas?
Old Aug 7, 2003 | 07:10 AM
drift's Avatar
drift
Flaccid Member
vacuum leak. check all vacuum lines and ensure all holes are plugged.
Old Aug 7, 2003 | 07:15 AM
Civic Type Sev's Avatar
Civic Type Sev
Is your car throwing a Check engine light?
Old Aug 7, 2003 | 04:32 PM
Kai's Avatar
Kai
Rotorphile.
Sounds like an EACV problem. Do you still have the old engine? Try swapping the EACV and see if that helps.
Old Aug 7, 2003 | 05:17 PM
Carguy's Avatar
Carguy
I haven't been able to find a vacuum leak, that's what I thought it was. It gets a check engine after about 15 min of driving. I don't have the old engine anymore (it's actually my nephew's car) but may be able to get to it at the wrecking yard.
Old Aug 7, 2003 | 06:41 PM
Kai's Avatar
Kai
Rotorphile.
Well, what code is the ECU showing? That will tell you in a hurry what needs to be fixed.
Old Aug 7, 2003 | 11:02 PM
Carguy's Avatar
Carguy
Does the Integra have a self-test mode? If so, how do I access it?
Old Aug 8, 2003 | 08:35 AM
pony2slow's Avatar
pony2slow
im new at hondas but if its like my crx there is a lil light on the ECU under the carpet on the passenger side .. if its not that sorry.. i tried to help
Old Aug 8, 2003 | 12:45 PM
Carguy's Avatar
Carguy
Thanks.
