b18b to b18c
Old Aug 6, 2003 | 10:00 PM
sspire's Avatar
sspire
Default b18b to b18c
ok, i have a b18b(odb1) witha GSR tranny, can i buy a b18c longblock head and ECU and use all the other existing parts?
Old Aug 6, 2003 | 10:12 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Someone correct me if I'm wrong, but the head is referred to as a short block?
And a short block probably wouldn't come with the intake manifold, right?
-PHiZ
Old Aug 7, 2003 | 07:29 AM
jlicrx's Avatar
jlicrx
normally - a complete engine is just what it says, complete with all accessories - starter, distributor, alternator, etc. - a long block is the complete block assembly with head and no accessories - usually no intake manifold - a short block is just the block assembly, nothing else
Old Aug 7, 2003 | 11:46 AM
PHiZ's Avatar
PHiZ
BOOST GOD
thanks, I have been operating under the wrong impression... Thanks for correcting me.
-PHiZ
Old Aug 7, 2003 | 04:24 PM
Kai's Avatar
Kai
Rotorphile.
First off, what do you mean by "all the other parts"?
Is it a complete longblock (with distributor, intake manifold, exhaust manifold, etc), or just a bare one (only the block and head)?
At bare minimum, you need a B18C intake manifold. The B18B distributor can be modified to work. Use the original mounts.
Old Aug 7, 2003 | 08:27 PM
sspire's Avatar
sspire
so all i really need is the distributer, head, block, intake manifold and throttle body and i'll be good to go?
Old Aug 7, 2003 | 08:35 PM
sspire's Avatar
sspire
btw the "longblock" comes with an Intake Manifold, Exhaust Manifold, Injectors, Fuel Rail, Throttle body, Alternator, and Distributor. would that be everything i need to chang ethe b18b to a b18c (other than the ECU) thanks for the replys.
Old Aug 7, 2003 | 08:59 PM
Kai's Avatar
Kai
Rotorphile.
Pretty much, except for a little wiring work.
