intake question
Old Aug 6, 2003 | 05:43 PM
bustah49's Avatar
bustah49
Mr. Motorhead
Default intake question
i have a 97 civic dx 1.6 non vtec. what intakes will fit on my car, and i am almost certain that they will flow better that what i have?like the 1 that is on the sohc v-tecs?
Old Aug 7, 2003 | 12:22 AM
Hondadog's Avatar
Hondadog
You should try a D16y8 or Z6 intake manifold. You have the D16y7? Correct? The y8 is probably the better of the 2. Its a pretty easy bolt on project as long as you have everything you need.
Here's a site you can check out .
I dont recommend using sealent like they do in the IACV opening but it will give you an idea of whats involved.
http://www.makuragi.s5.com/civic_99/Y8maniswap/
Hope this helps
Dog
Old Aug 7, 2003 | 09:14 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
the y8 would be a good bet, just make sure the iacv is the same
Old Aug 8, 2003 | 07:30 PM
importsyn's Avatar
importsyn
If all else fails you could always go with a drop in K&N OEM replacement filter.That is provided you don't mind the way the factory one looks.
Old Aug 12, 2003 | 07:42 PM
lkailburn's Avatar
lkailburn
college kid
about how much hp gains can you expect from swapping a y8 intake manifold on your y7?
Old Aug 12, 2003 | 08:23 PM
bustah49's Avatar
bustah49
Mr. Motorhead
who cares....it has to flow better than what i have now...and besides..every little bit counts:thumbup:
Old Aug 12, 2003 | 08:25 PM
bustah49's Avatar
bustah49
Mr. Motorhead
ttt
