2000 Civic EX
Old Jul 23, 2003 | 03:49 PM
jmf363's Avatar
jmf363
Default 2000 Civic EX
I recently purchased a 2000 Civic Ex and was looking for some performance upgrades for it. Im not looking for anyhting huge, just to gain some horsepower simply and cheap. If any one has any ideas they would be a great help. I was looking at the venom performance chips, and heard that in some cars they dont work too well. if anyone has some info that would be great too.
Old Jul 23, 2003 | 05:38 PM
Si_Sean's Avatar
Si_Sean
Its not worth playing with the ECU for SOHC in my opinion. Just do some basic bolt ons, and if you want to play with the ECU ide suggest a V-AFC.
Old Jul 24, 2003 | 05:17 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
one of the worst things i did in my opinion was put my exaust on when my car was still just a regular ex. it took away from some low-end torque, therefor making it a little less every-day drivable. also, the sound just drove me crazy whenever i had to drive it more than a few miles. i say get an intake, which only makes the engine roar when you WANT it to, and still idles quietly. it's cheap and adds some top-end hp. btw, the afc wouldn't do you much good performance-wise unless you had something more done than just bolt-ons (not including turbos/superchargers). it is fun to look at though
i've had a set of pulleys on my car for about a year now, and they free up some strain from your engine, therefore putting a bit more on the pavement. i'd suggest them as a good upgrade. i would not suggest putting much on your car that will draw attention, like loud stuff or wierd lights or anything. i only have an exaust still cause of my turbo. otherwise, it would go bye-bye on ebay.
Old Jul 24, 2003 | 07:43 PM
PHiZ's Avatar
PHiZ
BOOST GOD
I wouldn't reccomend the venom chip, I've never heard of it (other than mustangs/neons, etc.) , and I chip ecu's semi-professionally, there are a lot of other options. Chipping the ecu will make a noticible change in power, and then the regualr, letting it breathe more stuff... I/H/E.
-PHiZ
Old Jul 27, 2003 | 04:51 PM
forum95's Avatar
forum95
I'm Cooler than You
hmmmm anything is possible with the right amount of money....here are a list of mods you can do to make your civic a true rice burner: forged one piece crankshaft, forged rods, low compression pistons,high performance piston rings, forced induction headgasket, RACING SYNTHETIC OIL, Stage 5 port and polished head, equiped with stage 3 racing cams, custom built SPLIT intake manifold, 75mm throttle body, 96lb fuel injectors, Type R head, custom built GReddy Stage 3 Twin turbo 50PSI boost kit, Apexi exhaust, Complete tubular drag racing suspension, battery trunk mount kit, New fuel cell, stage 3 weight reduction, 6 speed racing Tranny, nitto 555 drag radials, 10 point rollcage, aluminum drive shaft, aluminum flywheel, AWD conversion, Custom Burnt dyno tune chip, Acylryc window conversion
That should be good for a daily driver like yourself.
