GSR rod sprayers
Old Jul 23, 2003 | 03:53 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
Default GSR rod sprayers
Does anyone know if it is possible to bolt in gsr/trpe-r oil sprayers into an LS block? If so is there a site that explains or demonstrates it? Any help will be appreciated.
Old Jul 23, 2003 | 04:06 AM
CivicRacr's Avatar
CivicRacr
not possible
Old Jul 24, 2003 | 12:24 AM
FyberOptik's Avatar
FyberOptik
Your rods don't need any additional lubing. They're allergic to oil.
Old Jul 24, 2003 | 04:42 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
Allergic to oil?? Everyone on here tells me that they dont get enough oil in that set up thats why they fail all the time.
Old Jul 24, 2003 | 06:22 AM
drift's Avatar
drift
Flaccid Member
the VTEC squirters spray the undersides of the pistons for cooling purposes.
besides, someone already said the correct answer... no.
Old Jul 24, 2003 | 09:47 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
I know what the sprayers do. I was just asking if they coud be put in. Does anyone know of anyone who put an LS rotating assembly into a grs block?
Old Jul 24, 2003 | 11:44 AM
FyberOptik's Avatar
FyberOptik
I thought i sent you email. And if you might as well stick with GSR internals on a GSR block if you have that block to begin with. Oh no! a thirty-something cc loss of displacement! Of course you lose a little torque because of that and the r/s ratio.
Old Jul 24, 2003 | 05:09 PM
TheRooster's Avatar
TheRooster
Former Senior Member
You could always fabricate a custom setup.... but the short answer: nah!
Old Jul 25, 2003 | 06:06 AM
rev's Avatar
rev
Like he said above, it would take a little fabrication. If you were serious you could just run a tap line into into an oil galley and run some -4 line in the block to some custom squirters mounted at the right angle.
