distributor trauma
Old Jul 23, 2003 | 12:17 AM
Civic2Scooby's Avatar
Civic2Scooby
Default distributor trauma
is it possible to run an obd-0 distributor on an obd-1 ecu if I change the plug on the obd-0 distributor to an obd-1 plug?
Old Aug 16, 2003 | 12:39 AM
PHiZ's Avatar
PHiZ
BOOST GOD
My initial re-action is that the OBD1 ecu is going to be looking for sensors that don't exist on the OBD0 dizzy.
Compare the pinouts, I might be wrong.
And it would be easier to change the engine harness plug, instead of the plug on the dizzy..
let me know how this goes, I'm interested.
-PHiZ
Old Aug 17, 2003 | 03:58 PM
Civic2Scooby
doesnt work....made an awful noise...the pinouts matched up, but I think it mite be running different somehow
Old Aug 17, 2003 | 09:32 PM
PHiZ's Avatar
PHiZ
BOOST GOD
did you match up what the colored wires do, or just the colors? Soemtimes they use the same colors for diff sensors. check that.
Maybe you can replace the internals in one of the housings with the other?
-PHiZ
Old Aug 20, 2003 | 11:13 AM
Civic2Scooby
tried swapping the internals but they are all together different. I tried matchin up the colors. I dunno if I can match it by sensor cause it is damn near impossible to get a helms in english on a first gen b16a.
Old Aug 20, 2003 | 03:11 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Here ya go.
http://tech2.hybridgarage.com/ecu.php?ecutype=pr3_a
Here's a little trick, it's simple, but it helps so I'll pass it on.
If you're confused what a wire does, find it's pin on the kick-panel connector, and see what color it is on the chart.
Like say I want to find CYP P, at the distribuotr. I find CYP P on the chart, find the pin, and see what color is run to it.
Good luck!
-PHiZ
