Urgent Help Needed :(
Old Jul 22, 2003 | 03:20 PM
XxAccord94jxX's Avatar
XxAccord94jxX
Default Urgent Help Needed :(
ok I'm at the last step to getting the '92 H23a1 started in my '94 Accord Ex
It don't run, but it turns ......I swapped the pins a6 + a11...and still havent got a run.....the motor ran fine when it was in my lude.......Also the ECU fuse kept popping ....later finding that the NEG pins were going to the POS pins in the plugs in the engine bay coming from the ECU....
Any answers and point-outs would be great! Thanks
Old Jul 22, 2003 | 07:06 PM
v4lu3s's Avatar
v4lu3s
are you getting spark and fuel?
Old Jul 23, 2003 | 05:17 AM
XxAccord94jxX
I'm getting spark, but not in a normal process.......It only sparks 1-2 times while turning the engine......and yes im getting fuel.
Any feedback on why my ECU fuse blew when I first pluged my harness to the engine????? the car is a '94 Accord Ex that came with a SOHC VTEC 5-speed....the motor is a '92 Prelude Si H23a1 with a 5-speed
I've never been so confused in my whole life
Old Jul 25, 2003 | 07:15 AM
v4lu3s's Avatar
v4lu3s
sounds like you got some shorts in your wiring harness. i would go over everything you cut and spliced etc to make the harness fit.
Old Jul 25, 2003 | 09:35 AM
XxAccord94jxX
Yes there are some shorts in the harness........More like the two different harnesses from the Accord and Prelude have wires going in differnt places.....
Anyone have some kind of wiring diagram of which wires to switch, cut, splice? Any info and point - outs would be great.
Old Jul 26, 2003 | 10:04 PM
v4lu3s's Avatar
v4lu3s
pick up the chiltons manual it has the wiring for the obd1 preludes and accords
all teh sensors are more or less in teh same area. its jsut a metter of exteding some wires, just make sure to use solder and heat shrink tubing...
