BOV question
Old Jul 21, 2003 | 04:34 PM
crxb16er's Avatar
crxb16er
Default BOV question
anyone know of a good BOV that can be set as low as 4lbs of pressure im looking for something around 4-6 lbs of boost on my stock internals, anyone know a good brand
Old Jul 22, 2003 | 04:10 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
i was runnign 5lbs of boost on a greddy kit and i had a greddy type-s bov and it worked great. i actually tightened it up a bit so that it would have a more crisp sound to it. when you get a bov tho you dont really set THAT to the lbs of boost you want, you need the wastegate set.
Old Jul 22, 2003 | 08:28 AM
anatolia's Avatar
anatolia
whatever you get the spring inside should be light.....considering the vacuum line assists in opening it somewhere around eaqual lbs. to a little more would be a good start , and if it were adjustable then you'll probably get it working correctly.
