Accord injectors in H22a in 5th GEn Accord
Old Jul 17, 2003 | 07:09 PM
SimplyDrift's Avatar
SimplyDrift
Default Accord injectors in H22a in 5th GEn Accord
Has anyone ever heard of using the accord injectors With the H22a when you swap it into a 5th Gen accord?
Old Jul 18, 2003 | 09:41 AM
accordhybrid's Avatar
accordhybrid
The accord injectors are to small are only 240cc and the OBDI prelude injectors are 345cc you can use them to start the car but you will throw a lean code.
Accordhybrid
Old Jul 18, 2003 | 10:43 AM
SimplyDrift
Would this cause a misfire? We seem to be having a problem with random misfires at idle. I'm sure they occur high in the rpm band, but we can't hear or feel them in anything other than idle. I would assume, that a smaller injector might starve the engine of fuel and cause misfires.
Old Jul 18, 2003 | 06:08 PM
accordhybrid
Yes that could case a misfire I drive with them for a while in my hybrid before i got the correct injectors just turn your fuel pressure to about 55-60 psi
Old Jul 19, 2003 | 09:41 AM
SimplyDrift
we have to get the correct injector resistor box. So we will see how this turns out when it comes in. The accord box won't fire the prelude injectors. ObdII car and harness, OBDI engine and injectors.
Thanks for you help.
Old Jul 21, 2003 | 07:22 AM
accordhybrid
What do you mean the accord box won't fire the injectors? Are you talking about the resistor box cause those boxes are teh same for all cars I thought the same thing and bought a prelude one and the resistance was 5.8 ohms on both packs so it must be something else. Also what is your set-up car engine and what computer are you using?
Accordhybrid
