VAFC hooked up to PM6 wire harness? HELP!!!
Old Jul 12, 2003 | 08:35 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default VAFC hooked up to PM6 wire harness? HELP!!!
Hey wheres a HOW TO on the VAFC hooked up to the PM6 wire harness? with d16a6 distributor and stock ecu (PM6)??? i know you can easily do this but i don't know where to start searching, is there any place on this site? thanks!
Old Jul 14, 2003 | 09:29 PM
ZiviCase10287
RacinMasonC
anyone?
Old Jul 19, 2003 | 05:16 AM
drift's Avatar
drift
Flaccid Member
D16A6 is a non-VTEC motor, therefore the VAFC is not fully compatible, and not recommended for use by Apex'i. this is why you cannot find a diagram for install.
try an SAFC.
Old Jul 19, 2003 | 07:15 AM
ZiviCase10287
RacinMasonC
try an SAFC.
i have a mini-me swap so yes its compatible with the head.
Old Jul 19, 2003 | 10:15 PM
ZiviCase10287
RacinMasonC
anyone???
Old Jul 19, 2003 | 10:25 PM
CivicRacr's Avatar
CivicRacr
find the diagram for the vtec head that you are using, thats if you changed the wire harness too
Old Jul 20, 2003 | 06:20 AM
ZiviCase10287
RacinMasonC
stock Si wire harness
would i just tap into the ecu wires? i just need to know what wires from the VAFC goes to what wire on the ECU cuz i got a Helms Manual that should tell me the wires from my ecu, i would think so. but i just need to know what color wire from the VAFC goes to where on the ecu?
IE: white wire from VAFC goes to TPS wire on ecu.
Old Jul 22, 2003 | 08:45 AM
drift's Avatar
drift
Flaccid Member
go to www.apexi-usa.com and download the instruction manual. it has the wiring diagram for the wires coming off the unit.
