White smoke, headgasket replaced....what else?
Old Jul 11, 2003 | 11:34 AM
petrv's Avatar
petrv
Default White smoke, headgasket replaced....what else?
There is white smoke from my exhaust, even at idle. I have replaced the headgasket, but the smoke is still there! What could it be?
Old Jul 11, 2003 | 06:35 PM
MikeR's Avatar
MikeR
and there wern't any signs of a crack on the head or block? if not, does the tail pipe smell of burnt coolent? is there any moisture coming out exhaust? and is your resevoir empty, if there isn't any coolent missing from your rad. or res. and oil is in it's place it sounds like it might be a fuel issue, does it smell rich?
Old Jul 12, 2003 | 11:04 PM
jeepxj66's Avatar
jeepxj66
lots of people mistake light blue smoke for white. Are you sure?
Are you losing coolant? If its not the gasket and you are losing coolant then you must have a crack that is letting water into the combustion chamber. The crack could be in the block or the intake side of the head. Fuel problems cause black smoke and is rarely mistaken for white water smoke.
Old Jul 14, 2003 | 11:21 AM
sunshine's Avatar
sunshine
Torqueless Wonder
when you did your headgasket, did you have your head milled and pressure checked?
Old Jul 22, 2003 | 11:27 AM
Si_Sean's Avatar
Si_Sean
check your plugs to see if they are all gunked up... if they are give em a good cleaning or replace them. Oil getting into the plugs could either be a cracked head, or crapped out rings. Unless you maybe put to much oil in, that could cause an overflow, and in turn bugger things up.
Old Jul 27, 2003 | 10:58 AM
Mac8008's Avatar
Mac8008
Synthetic oil will burn white.
Old Jul 27, 2003 | 08:25 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
if you replaced the head gasket did you get the block and head checked for warpage? if thats not the case i would start looking for a new block/head cause you probably got a crack somewhere
Old Jul 27, 2003 | 11:07 PM
ManTiS's Avatar
ManTiS
NinJA
If it doesn't go away, then rings/ringlands
